hunterdan
- October 21, 2004
- Fairless Hills, Pa
- 2010 Chevy Silverado
I just installed a dynomax Super Turbo catback system on my 98 OHV sport. Everything fits well and looks good. But, I should have done more research before hand. The pipe exits directly behind the passenger rear wheel, which hangs a little low, but wont hit curbs or anything. I ended up actually buying all the parts separately instead of buying the kit. The kit wasnt available, but all the parts were. What I think I should have done was get the muffler and the extension pipe for the OHV, but buy the tailpipe for the SOHC, which is 2.5" instead of 2.25" but could be fixed with a simple adapter. This would give me bigger pipe and the exhaust comming out in the stock location, which is higher than where I have it now. But I can always go back and buy the pipe at a later time and just replace it when it needs it. The short pipe that goes from the cat to the muffler was for a 4 door, so I had to cut that down to fit. This wasnt too hard to do at all and it works. The only problem I had was pulling the pipe and muffler out, but it was possible cutting the very end of the tail pipe off, as well as getting the muffler off of the stock rubber hangers. I just ended up cutting those off and buying new ones. Now, for sound, its not loud at all, but has a much better tone at idle while higher rpms sound similar to the stock muffler. I have not had it on the highway yet, but will test it out tomorrow. So to answer, will a dynomax kit for the 96-98 explorers fit a 96-98 2 door, yes, but you have to cut the extension pipe. But as I said, I may end up changing pipes and go with a pipe for the V8 or OHC motor as it it straight back instead of exiting behind the rear tire, plus its 2.5" And the pipe is mandrel bent and comes with a nice stainless steel tip which really sets it off. So far, Im happy with it and Im hoping it does get a little louder, but not too much. The install took about 2 hours to do, including modifying the pipe to fit as well as talking to coworkers. I did this in the parking lot at work, Advance auto, which is where I bought it. It made it nice since I had a nice supply of parts just a stride away. Sorry for the long post.
Dan
Dan
