Airbornemaikai
- September 27, 2013
- ID
- 2014 Ford Explorer Sport
Warning! Do not I repeat DO NOT mix E85 with gasoline in an ecoboost engine if you still have a warranty or even of you dont! The engine injectors and main CPU are not designed to handle E85 or any ethanol concentration over 10-15%in an ecoboost. The only alternative to getting an higher octane is to look for racing gasoline with higher octanes to mix with 91 octane gasoline. Using E85 will increase the ethanol content and ethanol has only 70% of the energy that gasoline has and would work against you.
Flex fuel engines using 100% E85 would have about 100 octane but use 30% more fuel than gasoline resulting in poorer mileage.
Great information!
To add: E85 would require the tune to command more fuel at WOT. The tune itself would have to be created for E85. One limitation thus far in the aftermarket for these ecoboost engines is fuel modification, ie injectors and fuel pumps. Our stock engine with a tune and a few supporting mods can max out the stock fuel system quickly, hence the reason people supplement with meth injection systems. To run E85 you generally want fueling to support the extra 30% fuel or so that you will need to command. Since our stock fuel system really wont support that, E85 isnt really something you will want in this vehicle yet.
In the future, when bigger fuel injectors and better/higher flowing "high pressure fuel pumps" are available, guys that want to push their cars even further will be able to use E85 if they want. I just dont think its feasible in this vehicle without fuel mods.
As mentions, the additional wear e85 can create negates the actual benefits unless you just do it once in a while.
