Bill MacLeod
- November 18, 2000
- Hamilton, Ontario
- 06 Ltd V-8
Well, finally got around to changing the plugs on my 06 on Saturday. Been putting this job off for 2 years now.
I got all 8 out with no breakage. Lucky, lucky, lucky.
Some tips for others that may be of help.
Warmed up engine to about 150 F.
Washed top of engine down to remove any dirt, oil crud, etc.
Use compressed air to dry and remove remaining dirt.
Removed air intake assembly.
Disconnect neg terminal. Removed injector harness, coil harness, removed coils.
Broke plugs loose about 1/8 to 1/4 turn.
Used Ford carb cleaner as per TSB. ( to just cover plug hex)
Let sit for at least 45 minutes.
Worked plugs back and forth no more that another 1/8 to 1/4 turn.
Let sit for another 30 to 45 minutes.
Used compressed air to cleanout accessive cleaner.
Set torgue wrench at 33 ft lb
Slowly removed plugs. (plugs/carbon was wet from the cleaner)
Installed new plugs with anti seize on barrel of plug. Torqed to 25 ft lb.
Will repeat this time next year.
You will need a 9/16 plug socket and might want to consider the Lisle extraction tool just in case. Didn't need mine, but I think I will keep it.
Not that difficult a job, just take your time and don't use excessive force. Slow and easy.
