WhiteLX
- June 23, 2007
- Riverside, CA
- 1998 Explorer XLT 5.0L
I need to replace the radius arm bushings in my 89 Ranger 2wd. I am going to be installing 3" drop beams so this is the perfect time to replace the radius arm bushings.
I have noticed that there are several choices for radius arm bushings. They have standard and eccentric bushings as well as short design and standard design. I'm not exactly sure what to get.
I was thinking about getting the eccentric radius arm bushing because they will allow for a +/- 2 degrees caster adjustment, which will may be helpful after lowering. I'm just not sure if I really need them. I'm keeping the stock springs and just doing the drop beams.
I'm also not sure if I need the standard length or short length radius arm bushings. Why is there a difference?
