jrod92
- August 29, 2013
- Napa Valley, California
- 2017 Explorer 4WD Limited
The ECM in my 94 Explorer is acting strange. Got out my Ford Shop Manuals and proceeded to go through all the troubleshooting tests. To my best deduction the ECM is stuck in limp in mode. The codes say no connection to MAF sensor and no ground to ECM from fuel pump. I ran all the voltage tests and ohm tested all the wires from the ECM plug to the MAF sensor and fuel pump. All test fine. MAF sensor 0.8volts at idle to 2.4volts at revs. Fuel pump steady 40psi at fuel rail, and dead heads at about 70psi. My question is, I have access to a ECM that is not Calif. aproved. Most likely won't pass smog. Its a F47F-12A650-MB. Mine is a F47F-12A650-DBA. Seems the DBA model is hard to come by. No one around here has one. All on back order. Yeah right. Does anyone know what the programing or parameter differences are between the two. I was thinking of trying the "MB" model until I can find a new "DBA" one. Any thoughts or suggestions would be great.
