IAmTodd
4x Explorer Veteran
- April 8, 2002
- Johnstown, PA
- 2015 Jeep
I've been on the hunt for a manual trans ECU since I did my swap. I was at the pick n pull today and found a '94 B4000 that met the same configuration. 4.0/manual/4x4. I had the part number for an Explorer, they didn't match but I figured it could be tuning difference due to weight. I read previously the difference was the Explorer ECU was tuned for more lower end torque. With that in mind I thought it would work in mine.
Swapped it out and upon startup the truck idles around 2000-2500 revs. The CEL came on for a few seconds, went on and as I came out of the garage it came on again. Turned the truck off and jumped the pins to read the codes. No codes.
The part number for the ECU is F47F-12A650-CJA.
