lonestar
- August 29, 2001
- lou,ky
- 91 XLT, 02 XLS
Hopefully someone here can help, given all the useful threads I have found in the past. I need some advice for an erractic high idle on a 88 Escort. I have checked the engine codes as follows
KOEO
73 refers to TPS (throttle pos.)
34 EGR not responding, suggest EVP (valve pos.) or PFE (press. feedback)
Memory
23 TPS out of range
32 EGR not respond, similair to 34
KOER
99 ECA has not learned to control idle
Now comes the weird part. I can quickly turn the ignition off and on and the idle usually returns to normal, indicating a electrical problem, rather than mechanical such as a stuck EGR. Then the high idle returns if revved above 2000-2500 RPM. Mant places suggest if you get a 73 code replace the TPS and test again. I replaced the TPS a year ago for the same problem, but no luck, so I just lived with it. Not sure about the calibration part. It appeared to have no way of calibrating it, just a little slot to catch the butterfly shaft. I'm thinking of also replacing the PFE, but it didn't cause an high idle in my mothers 91 Taurus.
The 99 code threw me. I was thinking maybe my ECA (computer) may be fried and I could pick oine up at a junk yard.
Now that I have my X to drive, I can work this so I can sell it, or drive it to work.
KOEO
Memory
23 TPS out of range
KOER
