WC Loc
- November 28, 2009
- Canton, OH
- '94 Eddie Bauer 4x4
New 94 Explorer (to me), took it home and check engine light came on
1. Need bolt size
2. Suggestions to clean, buy used, or buy new
Took it to AutoZone, cleared codes, and now they tell me it is running lean and pressue is low on one side.
Put in Lucas Fuel Injector Cleaner, noticed a difference on the pep from a dead stop.
Guy told me to look into EGR and clean, so i got a gasket but cannot get the EGR line apart from the EGR valve. Noticed a thread where someone with a 98 twisted the pipe and kinked it... Since the line is a $76 part and the valve $45, i'd rather not do that. My wrenches max out at 18mm and 1inch. Tried a cresent wrench, but at signs of rounding the nut, i stopped.
= Need to know the size i will need at the top and the bottom of the EGR Line.
Also need the size of the bolt where it attaches to the manifold. Just want to make sure i buy the right wrench... My guess is that it is metric since the bolts that hold the EGR Valve are.
Guess while I'm at it I should ask if i should clean it out w carb cleaner, buy used from the junk yard, or buy new? Obviously I will try cleaning b/c it's cheap
Appreciate any help / thoughts.
1. Need bolt size
