Are you referring to the DPFE sensor?
Yes. I am getting a code of P0402. EGR Overflow. I was told to check the hoses on the sensor to make sure that there is no cracking or dry-rot. I am also getting a spark knock. I read that if the sensor is going bad, it will show a code of P0402 and could cause spark knocking. P0402 does not mean that the EGR valve is bad. If the sensor is going bad, then the code will say that it is the EGR valve. Because it cannot relay back to the computer whether or not the EGR valve is bad or not. It will just show an EGR failure. I figured I would try the cheaper of the two.
I saw a pic of where it is at on a V6. But I own a 4 banger. Not in the same position.
I believe I know the general area of where it's at. I was actually kind of hoping someone might have a photo of it so I can see a visual representation.
Thanks for the help in advance.
