TPL96
- September 3, 2006
- Melville, Long Island, NY
- 96 Limited V-8
Greetings Forum -
I've been searching around for advice on how to repair and clear this EGR related code for over an hour w/no luck. So here goes my thread...
Pulled PO401 code insuff flow detected a couple months ago. I've been driving w/ the CEL on and lately the engine has started to run rougher and seems to backfire through the intake system under uphill load in high gear.
I started poking around the engine bay this afternoon and to my surprise the PCV valve was not seated in the engine. I reinstalled it and the CEL went off after a few minutes only to return in 1 mile or so (bummer).
The vehicle has about 93K on the clock and is generally reliable.
Does anyone have any suggestions as to what parts I should repair/replace as I'd like to have everything on hand before I start.
Also, is it best to remove the upper Throttle Body intake manifold to gain better access to the EGR and related parts. It's seems like a real knuckle busting job.
Many thanks for your advice/suggestions.
