Con Seann3ry
- September 15, 2003
- Eugene, Oregon
- 94 XLT
Reason this is in Explorer 911 is because I'm working on this right now and I would like responses as fast as possible.
A couple days ago I decided to finally chase down my check engine light. I went to Autozone and they read the codes and said "It's most likely a bad EGR valve" - so I bought a replacement and put it in. Once I put it in though I noticed that it's running very lean (and CEL came back on.)
I bought my own scanner at that time and just ran the codes. I got 327 in both the KOEO codes and the continuous memory.
My questions are: If my EGR valve was good and I replaced it unneccesarily then why would it change the way the engine ran?
I've also heard about this problem being mostly caused by a faulty DPFE sensor - My local Ford dealership wants 120 for this, but I've heard you can get them for 60 from Fordpartsnetwork. Is there a way I could test this sensor to be fairly certain it's the cause of my problems?
