EGR vs DPFE | Ford Explorer - Ford Ranger Forums - Serious Explorations
EGR vs DPFE
Mrafternoon
Charlotte, Northcacklacki
94 xlt
I'm a new addition to this forum, and I'm excited about being a part of this group!
I have a 94 exp XLT, and over the past month or so the CEL goes on and off, and now remains lit once the car has been drive 5 or ten mins. I ran the code scanner, and there are several problems related to the EGR Valve. I have read that EGR valve problems can be resolved by replacing the DPFE. I have to questions:
1)where exactly is the EGR and the DPFE located?
2)Is it prudent to replace both at the same time, or should i start with replaceing the DPFE, than the EGR, or Vice/Versa?
Thanks for y'alls help!
-MrAfternoon
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Mrafternoon
94 xlt
Thanks for the quick reply!
I knew someone would ask of the specific codes, and unfortunatly I don't remember them, but I am going to re-scan it and pull them down, but I do know for sure the the 3 different codes all were related to EGR errors.
Mrafternoon
94 xlt
Thanks
Thanks for the advice...I'm also hoping to find out exactly where the DPFE, as well as the EGR...any photos would kick @ss! I'm a novice at this kind of stuff, but i'm enjoying the learning process...
thanks for y'alls help!
Mrafternoon
94 xlt
Welcome to this forum! What were the codes that you pulled?
The code was 326-voltage to EGR is lower than expected....Any suggestions? I have already replaced the EGR valve itself, but not the position sensor or the solenoid.
Which (if either) do you suggest replacing?
Thanks!
BrooklynBay
Staff member
Moderator
Brooklyn, NY
BrooklynBay
Staff member
Moderator
Brooklyn, NY
According to my thread on EEC-IV codes, I have 2 things listed for that code:
326
(R,M)
Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittently - PFE
326
EGR Temperature Sensor Circuit Above Maximum Voltage (2.0L, 2.3L HSC & 3.0L SHO)
C
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Since your Explorer doesn't have any of those engines listed for the second entry, I'm going to assume the first description is the one that applies to your Explorer.
The list also suggests that a 326 can be either a KOER code or a CM code. Can I assume that it passed the KOEO test? Can I also assume that you haven't yet attempted the KOER test?
From what I have gathered from the few who have done "post-mortum autopsies" on their dead DPFE's, the internal circuitry of the DPFE becomes corroded. This normally causes the DPFE to no output any kind of signal, which will trigger KOEO codes. If you're not getting an associated KOEO DPFE code, there could be more here than a bad DPFE.
Mrafternoon
94 xlt
the 326 code came from a KOER test. Where is the DPFE located? Once I have located/removed it, can the DPFE be cleaned to return to to working condition, or is it best practice to go ahead an replace it? Once I pullled the EGR valve and tested it with a pressure gauge, it was broken, no question.
Thanks for all of y'alls help!
Jason94sport
FL
02 Sport 2WD 5 speed
It's the flat thing on the drivers side of the intake. It has 2 hoses coming out the bottom if it.
Mrafternoon
94 xlt
Is this also considered the EGR Valve Position Sensor? (2 vac hoses attach to the bottom, and an elctrical outlet on the right side?)
Thanks!
Jason94sport
FL
Yes it is
Mrafternoon
94 xlt
SUCCESS!
No more CEL, no Codes!
Thanks for ya'lls help and advice
I look forward to being a part of the community!
ma96782
Vancouver, WA
'94 XLT, 4dr
Learned something new today:
PFE - Pressure Feedback Exhaust Gas Recirculation
All '95 and earlier models and the 1996 5.0L V8 model used the PFE system
_________________________________________________________________
DPFE - Differential Pressure Feedback EGR
'96 and later models (except '96 V8) used the DPFE system. It operates the same way as the PFE except it monitors the pressure drop across the orifice allowing for a more precise measurement of the exhaust gass pressures.
Aloha, Mark
