Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
Ok, so I had a Flex a lite Black Magic 150 e-fan sitting around after I dismantled my last truck, so I thought I'd install it in my new truck. I was also interested in using a progressive fan controller instead of the on/off controller that comes built into the fan. Just thought I'd post up some of the install details.
For the fan install itself, it was pretty much in line with what you've seen with other Black Magic 150 installs on here. I didn't use the stock fan shroud because of the way the mounting brackets work. Only thing was that the air deflectors on the top and bottom of the radiator had to be modified. The air deflectors attach to the top edge of the radiator via some plastic "lips" that grip the top edge of the rad. Basically, I had to cut away the lips on the plastic air deflectors where they overlap with the fan brackets. Easy mod with the dremel. Also, since the transmission cooler is at the bottom and in front of of the radiator, I tried to position the fan so at least some of the airflow would be pulled through the tranny cooler (as everyone might have seen, the 150 doesn't cover the whole surface of the radiator)
Since I wasn't planning on using the thermostat of the efan, I opened up the compartment on it containing the circuits and pulled out the thermostat, circuit board, and temperature probe. This left me basically with a pair of wires going directly to the fan motor.
The progressive fan controller I bought was the Spal PWM V3...which is the newest version of the device. It was about 135.00 and came with all the wire harnesses, looms, connectors, fuse holders, etc...that are needed for a single or dual fan install. It utilizes your factory water temp sensor, and it also taps into your A/C compressor wiring as inputs. Out of the box, seemed like a nice durable unit with good features. Basically you can program the unit so it turns the fan on 50% speed at a user-selectable temperature, then it increases that speed to 100% at another higher user-selected temperature. It will also turn the fan up to 100% when the A/C is being used so you get good airflow over the condenser.
The Spal controller wasn't hard to install. Really most of the install time I spent just routing all the wires really carefully for the cleanest install possible. I put it in the engine compartment on the driver's side firewall right behind the battery and secured it using the included self tapping screws. This also put it in a good position for routing the power and sensor wires. For activating the controller itself, you need a switched 12v source, so I bought a Bussman mini add-a-circuit at the auto parts store and used fuse #41 (ignition system) in the power distribution box as the circuit to tap into. Spal didn't specify how many amps the activation circuit required, so I just used a 7.5 amp fuse (the add-a-circuit lets you use up to 10A).
I programmed the Spal controller to turn the Efan on at 195 degrees and then gradually ramp up to full speed at 210 degrees. I don't really want my engine getting that hot...I just want the fan to be turning as little as possible to minimize current draw and extend the life of the fan motor.
Upon testing it looks like the fan turns fast enough to keep me at 198 degrees at idle (I was at about 195 before). I could probably set the activation temp and max temp lower so that the fan ramps up more and keeps it at a lower temp...once I've driven with the setup more I'll see if this is really necessary. If I adjusted it I might drop the activation temp to about 190 and max speed at 205.
But anyway so far the Spal PWM V3 controller works exactly as advertised and I am very pleased with it. I haven't driven enough to comment on mileage yet, but throttle response and part throttle power seem to be improved. So far I'd say it was a worthwhile mod.
I'll post more comments after I've driven with it more and I am happy to get some pics and post them if anyone is interested.
