Electrical/Computer problem? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
asull85
The Storm Chaser
Agawam, MA
2016 Interceptor Utility
Callsign
WX4FUN
The other day when I started my 05 XLS, it died as soon as it turned over. I let it sit for a few minutes and then restarted it. Once it did, the check engine light along with a few others stayed on and the message center said 'AdvanceTrac Off' then 'Check AdvanceTrac'. I shut the truck off and restarted it again and all the idiot lights stayed off but I'm still getting the AdvanceTrac messages. I'm hoping its not a computer or electrical problem. Any suggestions?
Thanks
ICoull
Castlegar, BC
2003 Explorer & Aviator
Thanks
Most common trigger for traction control error msgs is a bad wheel speed sensor, after that it gets complicated with various inputs to the ABS/ Advancetrac module.
Stynx
Springfield, PA
2005 Explorer XLT Sport
Did it throw any codes?
1.8TTony
Location
California
Chico
2003 ST XLS
2004 ST XLT
Use a diagnostic tool with the ability to "Scan All Modules".....….that's the first step.
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
Agreed, pull the OBD2 trouble codes and if none are found, use a more advanced scan tool capable of Ford specific codes, and even better, real-time data.
I'd guess the vehicle is in limp mode. A bad wheel sensor/circuit could cause the message but would not cause (which?) other dash lights, and would not cause the engine to die so at a minimum, something else more important is wrong.
Before anything else, I'd make sure the battery clamps are corrosion free and tight.
Stynx
Springfield, PA
Yeah no reason not to have at least the free version of forscan if you are wrenching these old trucks.
