Solved - electrical help *FIXED* | Ford Explorer - Ford Ranger Forums - Serious Explorations
Solved electrical help *FIXED*
trashtruck
capital district, ny
1992 explorer xlt 4x4
hi all. while trying to diagnose a crank but no start issue on my 92 x, i'm coming up with strange codes. symptoms; running driving no issues, starts to sputter, struggle to run so i get home and shut down. now cranks but won't start. check codes, 211, so replace crank sensor with no improvement. disconnect battery to reset computer and now 211 is gone replaced by 114, 116? do i need to replace computer or investigate wiring more? have not yet checked for spark or injector pulse. crank, no start remains.
Gadget X
Gibsonville, NC
'94 XLT 5-speed
Have you checked the coil pack? That's a possibility, if it started running rough, and then quickly escalated to a no-start situation. If that's not the culprit, then you may be needing a new computer. If there's a Pull-a-part near you, you can pick one up for about $25. It would be a good place to start, anyway. Good luck with it!
FR-425
Used to be a road here.
Phoenix, AZ.
1994 Explorer Limited
Don't get tunnel vision on the codes, neither of those codes will cause a no-start.
Go to the basics. Check for spark and fuel first.
trashtruck
update; after more testing i cannot verify signal from crank sensor to ignition module. went to test sensor itself but multi meter died and now waiting on new meter. possible bad new sensor or wiring issue.
trashtruck
solved; broken pin inside connector. new connector and runs great.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
trashtruck
Which connector, the crank sensor?
~Mark
pin inside crank sensor connector broke. installed new connector, poof! running again
damnford
Location
pine city washington
94 explorer eddibouere
opposite of progress is congress.
