mhi1534
- June 26, 2013
- Iowa
- 2002 Ford Explorer XLT
Hello,
My 2002 Explorer recently has had multiple electrical issues which seem to be related because they all started at the same time. What I am experiencing is on a cold start I turn the key and I hear a clicking noise as if the battery does not have enough power, I turn the key back off and turn on again and the engine will turnover. Now sporadically when running, the ABS light comes on and whenever I turn on power to something(AC, fan blower, windows, lights...) I will get a loss of power for a split second. The radio will usually go off and then reset to the default volume level that it has always started at when initially turning over. Now if I am in drive gear and stopped when I turn something on(fan blower etc...) the RPMs will dip slightly just for that second.
Like I mentioned, sometimes it will start just fine in the morning and other days I have the poor turnover, ABS light & previously mentioned electrical issues. I thinking it is a bad wire someone which is sometimes faulting out. Where can I begin? I realize I could likely get a diagnosis at a shop fairly quickly but I would rather learn about the issue as I have been doing all the work on this explorer myself for the last two years and believe the knowledge gained to be valuable.
PS I did search the forums but I all I mainly found was the ABS light issues but not the same other specific issues I am experiencing. I understand it will probably be a good idea to replace the speed sensor as they are cheap and easy. I plan on doing this but I don't seem to think it is the root cause for the other issues, rather a effect of another electrical issue.
Thanks in advance.
Also, forgot to note sometimes I will only have the start up issues and no other electrical issues. But when I do have the electrical issues it is at a time when I did have a bad start up.
Again, forgot another issue. Sometimes the factory anti-theft will not have enough power to beep the horn or lock the doors from the keyless remote. I can then go and start the vehicle, sometimes with normal start up, others the previously mentioned start up issues.
Thanks in advance.
