DrHalfHand
- August 6, 2017
- Bloomington, IN
- 2003 Limited V8 4x4
Here's a puzzle for you all:
Every so often my 2003 4.6L V8 Explorer Limited won't start: when I turn the key it's as if the battery were completely dead. However, if I quickly disconnect the negative battery cable and then reconnect it then it'll start up on the first turn of the key. Basically my solution up until now has been to "turn it off and back on" to see if it fixes the problem.
Any idea what could be causing this? Something electronic that gets stuck open or shorted that then is released when the battery is disconnected?
