bigwiggs
- May 3, 2018
- Denver, CO
- 2011 For Explorer XLT
Ok, so here is a rundown on a starting issue that I have been experiencing. Hopefully I can get some help!
2011 Ford Explorer XLT with about 70k miles. New battery that is about 3 months old and has a full charge.
This only occurs on random days. When getting into my car, all normal lights come on and when I put my key into the ignition they stay on and everything looks normal. Then the issue occurs. When I turn the key, everything turns off and all power is gone. No clicking, turning over, or any power whatsoever. Seems like battery is completely dead, but I know that it is not. To get the car started (discovered by accident), I can take out jumper cables, attached to both + and - and run the - to a ground (piece of metal on my car). This causes the radio and lights to come on inside the car, without the key in the ignition. Then I get in the car, and turn the key and it will start. Sometimes it works the first time, other times I need to mess with the cables a bit to get it to work. What is happening?
I would be very grateful to get any advice on how to fix this, and my car is outside and I am willing to try out any suggestions or take pictures if that would help.
Thank you!
Thank you!
