eddie4.0
- November 28, 2008
- Phoenix, AZ
- 99 Eddie Bauer
I have a 1999 Explorer Eddie Bauer with the 4.0 SOHC motor.
I'm having one electrical system after another stop working. It started with the radio display going blank (radio still worked). Then the dash lights stopped working and then it spread to all the interior lights.
Now the 4x4 is off. The lights don't light up at startup for self-test, and turning the 4x4 switch does nothing. The OD on/off switch has also stopped working.
Here's what I've tried so far:
1. Bought a new dimmer switch - No effect
2. Checked all fuses - All are good
3. Looked for obvious wire breaks, bad connectors at the wire terminals - all look good
4. Disconnected negative battery terminal, and hooked up test light to positive terminal and ground - No obvious signs of a short
5. Connected multimeter to headlight and dimmer switch terminals and tested each circuit in connector:
I don't know where to go next with this. My Chilton's manual doesn't have a detailed enough wiring diagram to show me all the connections. Any help with this will be greatly appreciated!
- Infinite resistance in red/yellow wire from headlight switch to dimmer switch
- Infinite resistance in blue/orange wires on dimmer switch connector
