koda2000
- September 2, 2011
- x
2000 Mountaineer w/EATC controls:
Does anyone know where in the heater plenum the door is located that controls where the air comes out from? I assume it's controlled by an actuator and I think mine may not be working. The reason I believe this is that no matter which location I select, the air flow seems to come out of all the vents equally (dash, floor and defroster). The only setting that seems to blow exclusively from the dash vents is MAX A/C. As far as I can tell the rear seat vents, work normally, but then they're either ON or OFF. I get good heat and A/C, but defrosting takes a long time as you can't get 100% of the air to come out of the defroster vents.
