Email addresses.. | Ford Explorer - Ford Ranger Forums - Serious Explorations
Email addresses..
tdavis
Linux Guru, Jack of All Trades
Staff member
Admin
Pinole, CA
2001 F250/XLT Superduty
Callsign
KG6MAX
I've deleted the following block of email addresses:
1) anything with attbi.com in it's name (no longer exists)
2) anything with home.com in it's name (no longer exists)
This removed about 425 bogus email addresses from the forum database.
I will also start removing email addresses from the forum database if your email address generates a 550 or 554 SMTP error code. 550 means "no such mailbox", ie you entered a bogus email address; 554 is the same thing, but it's been returned to Postmaster (Yahoo! does this..)
Sometimes, some mail systems returns a 550 error code when it should not.. I can do nothing for you; there are just too many bogus email addresses clogging up the system and sucking down need CPU cycles.
If you are subscribed to threads and/or are supposed to get an email when PM'd, and you are not getting these, then please check your email address for correctness. Many are simply plain wrong or bogus. Some of you even have spam filters blocking email from explorerforum.com.
Thank you for you support.
