Engine Code P0430
mlteec1
use a code reader today had two codes both codes turned out to be p0430 tried to look up in book but this code was not in there anyone have a clue what this code is. thanks
steve6534
Southern NJ
'06 EB V8
Ms_Lakmflx
Panama City Beach
97 Explorer XLT
There's code readers out there that will tell you the code AND what it is. May want to invest in a better one.
imnotted
the Albuquerque.
98 V8 XLT
Wow...those posts were pretty friendly...
The code you have is the same code I have. It's basically an inefficient catalytic converter on bank 2 (driver's side). There are really only two practical causes for this code, assuming it's the only code you get. The first, and more expensive, is a bad cat. The second is a bad O2 sensor. If it's a sensor, it's more likely to be the downdraft (rearward) sensor. I just cleared mine, since my scanner won't read voltage outputs on my sensors (though it would for my old CSVT). If it comes up again, I'll swap the sensors, since they're cheaper and prone to going out after +100k miles, and try again. If it still fails, it's probably the cat. Hope this helps!
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
Most Efficiency issues are due to a bad converter. Ford split up the converters on the explorer so try to see which one you need.
-Drew
bigdo182
magnolia.ohio
93 xlt
my sons explorer is showing a 430 code ,cat system below threshold bank2 and also code po1127,exaust temp out of range,02 sensor tests not complete.i have erased the codes and check engine light and the check engine light will come back on after app. a 1000 miles,truck only idles bad when cold weather for 2 minutes and then it drives great,i think its the drivers side rear 02 sensor ,what do you guys think,thanks.
ozmedia
1997 Explorer Limited
Highly doubtful its your O2 sensor - without o2 sensor codes too
my sons explorer is showing a 430 code ,cat system below threshold bank2 and also code po1127,exhaust temp out of range,02 sensor tests not complete.i have erased the codes and check engine light and the check engine light will come back on after app. a 1000 miles,truck only idles bad when cold weather for 2 minutes and then it drives great,i think its the drivers side rear 02 sensor ,what do you guys think,thanks.
People like to change O2 sensors because A) they are cheaper than a cat and B) They are attached to the cat so they must be the issue - FALSE.
Having worked at Ford for many years, I have yet to see a P0420 or P0430 being caused by an O2 sensor. The sensor itself will generally throw one of two codes, either heater wire failure (doesn't heat up fast enough when truck goes into closed loop) or sensor out of range (very lean, very rich or switching to extremes). There's also the open or shorted circuit issue but that's not even close to what we are discussing. The 0420 and 0430 were designed so that if your O2 sensors ARE WORKING CORRECTLY, they are able to monitor the switches between front and rear to determine how well the cat is working. If they have the same switching action front and rear, it indicates that the cat is not converting gases properly and should be replaced. If it is switching quickly, it is definitely working. If it is not switching or out of range, it throws an O2 sensor code instead.
Has switching an O2 sensor worked? Yes, rarely. Sometimes a lazy front or fried rear sensor will add to the existing catalytic problems enough to throw the 0430 code before they throw their own code (RARELY!!!! It's not ODB1, codes are a fair bit more specific nowadays and O2 sensors are quick to throw their own codes), replacing them can keep the code off for a while or get through a smog test but it hasn't fixed the issue.
Some say you can and some say you can't CLEAN a cat, on Explorers it's actually quite easy to clean them due to the bolt on style. I've done it with great success before, it has also been scientifically proven too and a full report is available (direct link to PDF) . Go to a nutrition store, a U-Brew wine and beer store or (in my case) a candle making store. They sell citric acid in bulk (The candle place sells it because people buy supplies to make bath bombs with), you need 1-2lbs, it'll cost about $5 tops (U-Brew sells little packets for $4 each but I get 2.2 kg in bulk for $5.77 from Wix and Wax here).
Pour boiling water in the bathtub or get a giant camp cook-pot on the BBQ to simmer (I have tried the bath but not the BBQ, yet others said it worked well). Add 1lb of citric acid and agitate it with the cat submerged. Slosh it around inside the cat, pour it through etc. Let it sit overnight, add more boiling water, agitate, flush etc. You'll clean any carbon out without harming the precious metals. You will either get black sludge out of it, or it may turn light green from tiny droplets of antifreeze that stick to the converter over time.
To be scientific, the molecules in the converter's precious metals will actually spread apart and clump together over time. Citric Acid is proven to break up and rearrange these molecules to recover the metal's initial composition. (Cool, stuff huh?) Another Acid for cleaning, will actually do more for some of the precious metals while Citric Acid is better for others, is Oxalic Acid, it's found in paint stripping and wood cleaning compound such as Behr's Wood Cleaner. It is also proven safe but I prefer the straight citric powder than someone else's product that contains Oxalic acid, and who nows what else.
As for people using Var-sol in the gas tank or a bath? Maybe if it was a much older vehicle, that's just a bit too caustic for my sensors.
NOTE: If your CAT is actually dead, metals absolutely done for, or it rattles (busted to
pieces inside) cleaning does not work, buy a new cat. Cleaning just helps a carbon clogged cat perform better (like new in a few cases).
If you are here because of your Google search for bathing your kitty cat , DO NOT USE CITRIC OR OXALIC ACID!!! Try shaving it and using the washing machine and (insert generic laundry detergent here), hang dry on the line for a few hours on a sunny day and kitty will be full of life again!
So all that said, and thanks for reading ladies and gents, if you have a P0430 or P0420 on a Ford Explorer (or any other car for that matter) chances are your Cat is not working properly and will need replacing.
They are few workarounds, which are temp fixes at the very best, and you will eventually replace it. Unfortunately, new/aftermarket cats, don't have the same amount of precious metals inside and will be history in less than 5 years. But at $250 a piece for your Ex, what the hell, it's a super quick bolt on anyway.
DISCLAIMER:
I don't carry Explorerforum liability insurance or any other insurance for that matter, besides the stuff the G-men force me to buy in case I run into something/someone with my truck.
If you try any of the above methods and your truck dies or you get drunk and run someone down or you snort the Citric Acid and get a nosebleed or you get busted with the bag of acid in your trunk and they think you're pushing coke or any and all other boo-boos, brain farts and flubs, it's not my fault, okay?
Fix your truck at your own risk!
Good luck and may fixing your vehicle be as pleasant as being kissed by a thousand fluffy kittens.
(LOL, this post is peppered with 'cat' and 'kitty' so many times, it's bound to be Googled by cat lovers looking for grooming assistance. :) )
06BlackXLT
Boston, MA
06 Explorer XLT 3V 4.6
Great Thread,
Any thoughts on OEM or Aftermarket?
I think the local Midas uses Walker brand.
A local independent exhaust shop is pushing me to OEM cats. Thought process being, they don't want the truck to "reject" the aftermarket pieces that are non-returnable then have to buy OEMs anyways.
fordapprentice96
Explorer sport sohc 99
DISCLAIMER:
my engine was flooded 4 thousand kilometers ago. it got into the exhaust would my best bet would be to change the cat? i have this code and to be clear it is the driver side. also i noticed a tiny leak that you cant hear unless you roll down the window
diegopuente
durango México
2006 eddie bauer
i have a 2006 4.0 with the code P0430, i removed the driver valve cover and put silicon on it and no more code after 150 miles it come back again, when i removed the intake manifold i take this picture where the cylinder six is more carbon clean than the other five, whas does it means?
https://www.pinterest.com.mx/pin/663647695061443925/
and still have problem the coolant doesn´t return to the radiator when is cold i have replaced almost all the coolant hoses, the radiator( it had leaks), the water pump, and checked the pressure on the coolant system and keep the 20 psi
does i have a bad head gasket?
if i put a gasket sealer in a good engine could it be damaged?
thanks!
diegopuente
durango México
2006 eddie bauer
this is the image of the cylinder inlet, where the cylinder six is more clean of carbon what could means? the engine has code P0430
SB98UKexplorer engine light on but no code? EEC V 3
G 2004 Explorer check engine soon light with a code P0401. EEC V 4
C Check engine light - code reader UK EEC V 2
G P0128 engine code EEC V 3
X Factory engine running data EEC V 0
P Check engine light. EEC V 1
S 2003 Explorer with a check engine light. EEC V 3
F Check engine light. EEC V 1
F 99 Ford Explorer SOHC 4.0L. Check engine light with P0171 & P0174 codes. EEC V 4
7 Check engine codes. EEC V 3
D My check engine light is on. EEC V 3
A 2006 Ford Explorer with a check engine light. EEC V 1
R Check engine light P0300 and P0442, but at the same time. EEC V 4
S I need help with engine codes. EEC V 1
T Check engine light problem. EEC V 4
W engine runs but randomly dies EEC V 0
M My check engine light is on. EEC V 1
C Check engine light with codes. EEC V 8
G My check engine light is on. EEC V 1
J engine running rough EEC V 2
V Engine light on EEC V 16
P Check Engine Light: P0171 & P0174 EEC V 47
M P0402 code. EEC V 1
R 2008 Explorer P0456 Code EEC V 0
V P0351 error code solution explorer EEC V 0
J OBD2 code scanner EEC V 0
R 2002 Ford Explorer XLS. Code P0303. EEC V 3
T 1997 Ranger XLT. Code P1131. EEC V 1
C 2001 Explorer. P1409 code. EEC V 3
S Code P0171. EEC V 6
W 2005 Explorer. Error code. EEC V 1
E Diagnostic code P0506. Idle air control system RPM. EEC V 2
W 1996 Explorer 4.0L with an air bag code 52. EEC V 10
B Code P1401. EEC V 3
J Code P0756. EEC V 2
R 2003 Ford Ranger 16V 2.3L. P2004 error code. EEC V 8
0 Help! Code P0303. EEC V 6
A 2008 Explorer 4.0L with a code P0191. EEC V 2
J Code P0128. EEC V 2
R Camshaft position sensor code P0340. EEC V 5
F 97 Explorer 5.0 V8, getting p0443 code EEC V 0
T Code P1747. EEC V 2
4 MPG recently dropped- EGR code. EEC V 9
A Code P1715. EEC V 29
F Sport Trac with a P0174 code. EEC V 5
J Rough idle with a P0179 code. EEC V 4
J Help with code number P0304. EEC V 3
K P0304 error code on a 98 Ford Explorer 4.0L OHV. EEC V 5
1 Code P0506. EEC V 8
F Error code 648. EEC V 1
Similar threads
