misho
- October 15, 2009
Hey guys. This is gonna be long so be prepared lol.
So, a while ago, coolant was leaking near the exhaust gasket, and i suspect the head gasket is blown. Every week i needed to add coolant, and leave spots on the ground everywhere i parked.
Anyway, so i got some head gasket sealant, and it did the fix. The next day car didn't leak coolant.
But 2 days later, I start driving, and the temp gauge was working and raising to normal temps, but it kept going till the max. I turned on heater etc, to cool as fast as possible, and shut it off. My overflow tank was overfilled, and coolant all over it. I checked the radiator, and it was half full. waited a few minutes, and then i started the car up. The temp dropped to below operating temp immediately. So i drove off. Then the car reached op temps fine, and kept steady near it.
Problem 1: the rad does not suck in the coolant from the tank :S, So i filled in the rad myself.
So a few hours later when the car was fully cold, i drove it again, and SAME issue happened. I drive, overheats, let it cool, then runs fine at normal op temps.*
This ONLY happens when the car is FULLY cold, ie more than 2 hours since last drive.
So what i think, since the head gasket is probably blown, air gets in the system, and pushes out the coolant from the rad, into the overflow tank :/
*Another thing i notice is that since this started happening, the temp sometimes drops a bit if i run heater, or drive faster at low RPM or in neutral down hill.
Basically same issue as this guy: http://www.explorerforum.com/forums/showthread.php?t=304082
Background info: Temps are about -10C here, 14F. Car has 122k miles on it.
1999 explorer 4L ohv.
Note: There is no coolant mixed in with the oil.
So whats going on here :S
Help guys
Thanks
Help guys
Thanks
