Ferreus
- April 13, 2010
- Cape Coral, FL
- '01 Sport
Hey folks,
2001 Explorer Sport 4.0L OHC
I was driving along today when my engine stopped abruptly - no sputtering out. Now it cranks, but does not turn over. I tried spraying starting fluid, but i cant get it to burn. I can get a spark. I have fuel. My pump primes. I tried replacing the camshaft position sensor, but this did nothing. i have no money for a mechanic, what should i try next? If my timing chain broke, would I notice any noises?
EDIT: The CEL does NOT stay illuminated when cranking. The Haynes repair manual lists a method to test the CMP sensor with an AC voltage meter, I attempted this test but got no readings (which is the result to indicate a faulty CMP), but I cant get the voltage meter to show me numbers on anything, so I may have a faulty meter or I'm using it incorrectly. The CEL has been on for years, but goes off for varied periods of time, so I never had it read with a scanner. I have no access to a diagnostic scanner unless I have the vehicle towed somewhere. I checked for spark by removing a wire and using a screwdriver to connect the wire to the outside walls and i saw a spark, but maybe its not enough? If it had spark, wouldnt the ether ignite?
I've had several Ford No-starts in the past, but they were all easily spotted fuel problems.
