Mart1n
- July 19, 2018
- Laval, Quebec
- 2006 X LTD 7 pas 4x4 4.6
Hi, I have the roaring (wooshing) what ever you want to call it sound issue in my 2006 4.6L 6R60. The engine fan engages excessively (while under very light load) and randomly. The radiator is good, cooling fluid level is good, heat reading is good (stock cluster gauge) and no other reason to think the engine is overheating. I have no reason to think the tranny is overheating (no smell or other signs and smooth shifting). However, the tranny will sometimes downshift from overdrive to 5th or 4th gear under relatively light load at highway speed while the engine fan engages. This is very tiresome and fuel consuming on long trips.
I'm trying to find the troubleshooting process to try and get this fixed in a methodical way (from cheap and easy to expensive and complicated). I,ve read about the thermostatic valve on the 6R60 sending a false overheat measurement to the PCM kicking in the fan. However a valve can,t send a signal, it must be some kind of heat sensor in the tranny?
Sorry for the long post, but trying to give you the facts. Does anyblody know of the trouble shooting process I could use, where I should start?
Thanks!
Thanks!
