2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Background
Associated diagnostic trouble codes (DTCs):
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
The PCM computes the power of each cylinder and when one is low reports a misfire for that specific cylinder. Typical misfire sources are ignition, fuel injection, low compression, or a defective evaporative emission system.
Ignition problems could be due to a bad plug, wire, coil or crankshaft position (CKP) sensor. Sudden ignition related random or multiple misfires on more than one bank are probably due to a bad coil or CKP sensor. Ignition caused misfires are the most likely to occur and (except for the CKP sensor) the easiest to isolate and eliminate.
Fuel injection problems could be due to a clogged fuel filter, a failing fuel pump, a defective fuel pressure regulator, or a bad fuel injector. The only problem that is cylinder specific is a bad injector. Misfire DTCs in conjunction with too lean or too rich DTCs may be due to the abnormal air/fuel ratio. Mixture related DTCs should be eliminated before pursuing misfire DTCs. See Lean condition procedure A common cause of fuel related misfires is a clogged fuel filter. See Why change fuel filter? Another common cause is a failing fuel pump which is frequently caused by a clogged fuel filter. In 1999 Ford switched from a fuel return system with a fuel pressure regulator mounted at the fuel rail to a fuel returnless system with a pressure damper mounted at the fuel rail and the fuel pressure regulator mounted in the fuel tank. See Ford Explorer Ranger Fuel pressure test procedure A clogged fuel injector can sometimes be corrected by adding fuel injector cleaner to the fuel tank. If the fuel filter is soon to be replaced (every 30,000 miles), wait until the replacement is accomplished and then add the fuel injector cleaner.
Low compression could be due to worn/broken rings, worn or sticking valves, blown head gasket or cracked head. Low compression on all cylinders in one bank indicate a slipped timing chain for that bank.
