Engine Miss/Bucking only in Neutral/Park @3000 RPM or higher
jedbmw
Medford, NJ
Thanks in advance
2002 Ford Explorer Sport XLT
6 Cylinder – 102,000 miles
Engine runs fine/normal in drive under load. Stomp tested vehicle up to 5000 RPM no problems, engine performs normal.
When the engine is running in neutral/park and I stomp on the gas, at about 3000 RPM the engine appears to be starved for fuel, RPM jumps/cycles between 2500 – 3000 RPM.
Cycling happens when I slowly raise the RPM in park/neutral. I notice a little engine roughness/vibration when doing this gets worse at higher RPM
I have no `check engine` indication.
- Installed a new fuel filter and new Spark Plugs so far.
John
Scotty J.
Packin
Little Rock, Ar
'02 Ford Ranger XLT
Sounds like a Rev Limiter, I have found that my Ranger 4.0 SOHC does the same thing. Mine is automatic and has a speed limiter at 90mph as well.
SESCOKID
LAKELAND, FL
2003 SPORT TRAC
I had the same problem and looking through the messages here i found someone had a crack in teh small elbow hose for the pcv valve near the intake and looked - sure emough there it was !! Look under the intake cover with the engine size logo on it
