engine missing and tranny won't shift 04 explorer 4.6
mcexplorer04EB
Vergennes,VT
2004 Explorer EB
Good morning,
As the title states engine is missing under load. At idle it sounds great?? Also on the same test drive the transmission would not shift unless I did it manually. She has 206k, body is in decent shape and i am excited to get this beast running as she should!! 0355 and 0356 were present and code 0171 was present after the drive.
Thanks for the replies
Marcel
01STrunner Bolt on engine missing 2001-2005 Explorer Sport Trac 13
P Engine Oil Recomendation 2001-2005 Explorer Sport Trac 4
D Engine Swap - Now PATS won't let me start? 2001-2005 Explorer Sport Trac 18
R 4 cylinder engine swap? 2001-2005 Explorer Sport Trac 23
T Engine Air Intake Hose hole? 2001-2005 Explorer Sport Trac 3
R Questions about engine swapping with 2010 mustang 4.0 2001-2005 Explorer Sport Trac 2
K 2001 Engine Bay 2001-2005 Explorer Sport Trac 1
A 4.0 V6 Engine Start/Stalls 2001-2005 Explorer Sport Trac 2
F Introduction and engine troubleshooting 2001-2005 Explorer Sport Trac 2
B 4.0 Reman Engine Info 2001-2005 Explorer Sport Trac 1
koda2000 I did something dumb (re-titled 4.0L SOHC engine tear down) 2001-2005 Explorer Sport Trac 61
S Engine lights on no key in ignition 2001-2005 Explorer Sport Trac 20
koda2000 SOHC Engine Removal/Rebuild/Install - Done! 2001-2005 Explorer Sport Trac 334
2 4.0L Engine Year Compatibility? 2001-2005 Explorer Sport Trac 12
X 04 Sport Trac, replaced engine once already 2001-2005 Explorer Sport Trac 2
D Engine smoking... 2001-2005 Explorer Sport Trac 6
H Explorer Sport Trac P0320 engine stalling 2001-2005 Explorer Sport Trac 0
S Solved Engine overheating. 2001-2005 Explorer Sport Trac 5
P Other engine oil leak. 2001-2005 Explorer Sport Trac 4
D Engine fitment 2001-2005 Explorer Sport Trac 12
S 2003 Sport Trac oil on back of engine driver side. 2001-2005 Explorer Sport Trac 2
A Engine turns over and runs for 2 seconds but immediately stops 2001-2005 Explorer Sport Trac 0
J Engine break down after 3000 rpms 2001-2005 Explorer Sport Trac 13
K 2003 Explorer Engine Number 2001-2005 Explorer Sport Trac 4
J Engine swap 2001-2005 Explorer Sport Trac 2
J Engine Misfiring on Bank 1 2001-2005 Explorer Sport Trac 4
B Sport trac not starting engine 2001-2005 Explorer Sport Trac 2
W Engine knocked for 60 seconds then went away. 2001-2005 Explorer Sport Trac 6
E 01 Sport Trac engine shaking 2001-2005 Explorer Sport Trac 0
W Need help identifying Engine Parts 2001-2005 Explorer Sport Trac 2
T 01 Sport Trac Flashing Check Engine Light 2001-2005 Explorer Sport Trac 16
J Engine Misfire 2001-2005 Explorer Sport Trac 6
P Engine Compartment Gound Wire...just hanging. 2001-2005 Explorer Sport Trac 2
All out Need to replace my engine 2001-2005 Explorer Sport Trac 7
W 2001 Engine Noise? 2001-2005 Explorer Sport Trac 8
S Vacuum question after engine instal. 2001-2005 Explorer Sport Trac 0
R Sport trac needs an engine 2001-2005 Explorer Sport Trac 3
Paul Fithian Oil Filter Confusion - Job 1 Engine 2001-2005 Explorer Sport Trac 3
J Sport Trac engine rattle after replacing timing chains 2001-2005 Explorer Sport Trac 5
F 2003 Explorer engine swap issues 2001-2005 Explorer Sport Trac 7
E Fuel smell after engine is turned off 2001-2005 Explorer Sport Trac 5
B 2001 Explorer Sport trac engine shut off 2001-2005 Explorer Sport Trac 3
P 2004 Explorer timing cassettes replaced, engine just "spins" 2001-2005 Explorer Sport Trac 11
P 4.0l Engine Timing Chain Tensioners, Replacement Schedule 2001-2005 Explorer Sport Trac 31
S 2002 sportrac engine replacement using later year 2001-2005 Explorer Sport Trac 0
W Engine fit for 03 sport trac 2wd 2001-2005 Explorer Sport Trac 5
G A better engine for a 2003? 2001-2005 Explorer Sport Trac 14
E 2001 Sport Trac ... Engine "Problem" & Replacement 2001-2005 Explorer Sport Trac 8
H 2001 Thru 2003 Explorer Sport 4.0 Fuel Line From Filter To Engine 2001-2005 Explorer Sport Trac 1
A 2002 sport trac engine / trans removal 2001-2005 Explorer Sport Trac 2
Similar threads
