Engine overheats when Idling | Page 4 | Ford Explorer - Ford Ranger Forums - Serious Explorations
efBrianM
Spring Hill, Ks
95 Ex Exp, 01 Ex Sport
Have you replaced the upper and lower rad hose. Sometimes they collapse. Check to see if they are soft.
I have not seen any hoses collapsing. Since the hoses were 20 years old and 188,000 miles on them, I went ahead and replaced them.
efBrianM
Spring Hill, Ks
@efBrianM
Let's keep this simple :)
Re-Scanning this 3 Page thread, what stands out to me is that you've written that your Ex does not and has not:
* Boiled Over
* Entered into the Red Zone of the Factory Instrument Cluster Temp Gauge
BUT despite those two points, you feel that the engine is running hot.
OK - so lets try the following - getting some empirical data = actual temp numbers.
Let your EX warm up and get to the point where you feel the temp is too high.
At that point, plug your scanner/Forscan into the OBD2 Port, toggle to the Current Water / Coolant Temperature, and get back to us with what that temp is.
Hope that helps - :)
Forscan dongle is on its way.
