Engine Rattle On Start Up
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
2018 Explorer Sport - cold start - rattle noise. Did not go to dealer yet.
Welcome to the Forum.:wave:
Can you tell if it is coming from the engine or possibly from underneath the vehicle?
323citopaz
Philadelphia
2016 Explorer Sport
Definitely from the engine.
Checked everything around (outside) what possibly can rattle - nothing found.Noise coming from engine 100%
And it's only 25K
peterk9
Staff member
Moderator
Callsign
VE3
And it's only 25K
I know it only has 25k on it but I wonder if it could be the timing chain?
donalds
Location
Stem
Nc
1999 ford explorer sohc
Slap slap slap go the timing chain that sucks :angryfire:
peterk9
Staff member
Moderator
Callsign
VE3
I’ve read all about that TSB but oddly it doesn’t apply to the 2013+ Ford Explorer Sport, the Ford Flex’s with the same motor or the Ford Taurus SHOs with the same motor.
Any update on this issue?
323citopaz
Philadelphia
2016 Explorer Sport
7/25/2019 - Explorer at dealer for diagnostics
Will post update after .
410Fortune
ICE Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Timing chain tensioners should be replaced at 60-90K miles, if you are hearing the cold start rattle now its time for new tensioners.
If you catch the "rattle" early enough the damage will be lessened.
Change your oil every 3-5000 miles
Silly they still have issues with cold start tensioner issues even with the engines in 2014!
peterk9
Staff member
Moderator
Callsign
VE3
Emyshorts
Denham Springs, LA
2013, Explorer XLT
Wasn't the sport package the 3.5ltr twin screws only? The 2.0 turbo is the rattler, not the turbos on the 3.5 ecoboost.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
If it was the timing chain wouldn't it make noise every time you started the engine? If it runs/starts normally at all other times I wonder how serious it could be. Are oil and fluid levels where they should be? Any exhaust smoke?
Often the tensioners are oil pressure actuated and rattle first after they drain, and lose their holding pressure. Not sure if these motors use hydraulic tensioners, or not.
Mbrooks420
High Voltage.
EF Vendor
Any motor with a timing chain can develop a rattle.
TIgertas32
San Diego, CA
2017 Ford Explorer Sport
Does anyone have an update on this? I’m assuming it’s the timing chain. Was it covered under warranty? Or a TSB like the F-150s?
changed oil a couple of months ago and it showed up. Told the dealer when I had another problem.
Listen here. You can hear right after it cranks over.
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
BMan did you happen to change the oil filter and then started to hear the start up noise?? If you did, the anti drain back valve in the new filter could be bad. Just curious.
Tsuga
2013, Explorer, Sport
That is definitely not turbo rattle. You may have an oil pressure issue or some kind of blockage around the pump/pickup. What is the oil level and what does it look like? I would try pouring some oil in right before you start it and see if there is any difference. That would help rule out a possible oil pump/pressure issue.
The cold start rattle always happen on cold start and even after an oil change. Unless the Tech did not put in enough oil when he changed the oil.
Tsuga
No, I have not had the issue resolved yet and it has been over 1.5 years since the issue first appeared. There is another issue that nobody seems to be able to diagnose, which is the shudder at 50 to 60 mph.
Laurenbrooks
Cambridge
2014 explorer sport
I know I’m late to this thread but was wondering if you got any answers about the rattle and the 50-60 shudder. I’m having the exact same problem with my 14sport explorer.
mguy13sport
2013 Explorer Sport
Drivetrain shudder that does not go away could be the PTU (power transfer unit) or bad / unbalanced tires. Obviously check the tires first or move the front ones to the back and see if it continues or changes. The PTU is the weakest link on the Sport drivetrain
Tsuga
Yes, I had the timing chain replaced last summer and it got rid of it. My Explorer was sluggish and wanting to stall on a hill and soon after that it had a service engine light showed up intermittently. We plug the scan tool in and it showed a DTC for cam shaft sensor. Took it to the dealer and they did a further diagnostic and told me the timing chain was slacked. After the chain replacement, the shudder was gone and the rpm between 50 and 60 is a bit higher than before the timing belt replacement.
The rattle that I have is maybe a heat shield issue, because I still have it.
