Um, unhook everything, unbolt your motor mounts, unbolt your trans bellhousing , unbolt your torque convertor(access TC nuts through small rubber cover on lower drivers side of engine... That is that. Overall it may be a small PITA but nothing too complex. Just remember that you know absolutely for sure where each and every vac line, and nut and bolt go to. I usually label my vac lines 1-1 on each side of the connector, then 2-2 and so on so I match the numbers and plug them back together. I remember where the vac lines go anyways, but it will save time when reinstalling.
