Engine revvs when braking. Any Ideas? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Rabid Hobbit
2006 Explorer V6
Hey I've got a 06 Explorer V6 (26k) and for the past 2 weeks my engine has been revving when braking. Not horrible but noticable about 1k rpm jump up. This seemed to start after my engine started knocking and stalled going up a large hill, after i cut the engine off and back on it never stalled or knocked again. I have no idea if these are related but figure it should be noted. Any ideas why it would rev like that? Thanks :)
BrianDye
I'll have another...
Monroe, MI
2006 XLT
Could your brake pedal somehow be pushing your gas pedal?
Wires caught or something....?
fixxxer
Aurora, Co.
93 XLT 4X4
Check to make sure the carpet isn't bunched up and causing problems and check the throttle cable too.
Rabid Hobbit
2006 Explorer V6
I didn't check to see if the carpet itself is putting pressure on it. I know there is no wires or floormats touching it but I can check that when I get home today. Also I heard a bad IAC could cause a dip in rpms but could it cause a rise in rpms?
Rabid Hobbit
2006 Explorer V6
What am I supposed to look for on the throttle cable. You mean just rev it up by hand and see if it still does it.
big5dogg
newark california
1996 explorer 2dr. 4.0
maybe brake booster it runs off your engines vaccum problably faulty
Rabid Hobbit
2006 Explorer V6
Is a brake booster user replaceable or something that only a service tech should repair. Also is there some surefire way to check it. Thanks
fixxxer
Aurora, Co.
93 XLT 4X4
Just check to make sure the cable isn't routed in such a way that pressing on the brake pedal doesn't cause the throttle cable to tighten up and cause the acceleration. Another thing to check would be a vacuum leak at the brake's vacuum booster. A sudden loss of vacuum when the brakes are used could cause a change in the air/fuel ratio.
Rabid Hobbit
2006 Explorer V6
Yeah I think yall are right about the brake booster. The brake pedal has seemed a little funny lately too like its pushing back towards me when I slow down. I'll check for a vacuum leak this weekend. Thank you fixxxer and big5dogg. You've been a big help. :)
fixxxer
Aurora, Co.
93 XLT 4X4
You're welcome and good luck!
dothedeww
West Friendship, MD
2006 Explorer XLT
Just last night...wheenever I would get on teh gas hard...it would knock real bad. Then on my way home whenever I braked it would rev...I would have to hold on the brake at a stop light or it would take off. Dont know if this was just a coincidence or if im experiencing the same thing. I have an 06 XLT with 76k.
fixxxer
Aurora, Co.
93 XLT 4X4
Besides the knocking, did you experience any other performance issues? You might also have a vacuum issue related to the brake booster, check for loose or missing vacuum hoses and listen for vacuum leaks in that area.
dothedeww
West Friendship, MD
2006 Explorer XLT
No real performance loss..I just checked for vacuum problems last week...couldnt find a single leak.
I did just install the KKM intake before the problems yesterday....I guess that could be affecting the engine?
shaker1
Algonquin, IL
2006 Explorer XLT 4X4 4.0
If you had a vacuum leak at the brake booster you would be running lean from unmetered air. Then after adding even more air with the intake it might get more noticeable.
tbe2002
Longmont, CO
08 Expedition Limited
Just to let you know there is no throttle cables on 03 and above explorers. It is all drive by wire. The pedal is just attached to the firewall with an electrical connector coming out of it.
Rabid Hobbit
2006 Explorer V6
Well I got the problem fixed. I checked the brake booster and lines and they we're all fine. So reluctantly I took it to the shop and it turns out it was a computer error causing me to downshift early. That why my rpm's were spiking when I was braking. It was $175 to flash my cpu so not too bad. But thanks for all the responses. :)
shaker1
Algonquin, IL
Good info. So few people post solutions, just questions. Cheers.
rmurray
Los Angeles
'03 XLS and '06 XLT
I think I might have the same problem. Engine revs when stopped or braking. Increases about 1k RPM. Now, I've noticed that when I'm accelerating, it sounds like rushing air through the motor. The tranny seems to be less inclined to shift, but then it goes away. It could be a vacuum problem I guess. Seems odd that it comes and goes. Any ideas?
