rydrew55
- July 13, 2010
- Connecticut
- 98 XLT
2 ton crane too wide
Thanks janolsson, but streetrod is right. I might need to straddle the stands at an angle. The crane is just too big to go between, and the legs are angled and too narrow near the base to go around.
What do you think about moving the stands to the frame rails in front of the crossmember. I could position the crane with one in place while jacking the truck near the door. Then when it's in place, put the other stand in, and drop the truck on it.
The crane is much narrower close to the base and should fit between the stands at the frame rails so close to the front of the truck.
As I recall you purchased the larger 2 ton crane that probably has a wider stance than the 1 ton crane I and many other members use. You may not be able to get the jact stands far enough apart for the crane legs to fit between them. You may have to straddle one of the jackstands with the crane legs and pull the engine with the crane off center. Once the engine is free and raised some you can rotate it about 45 degrees (diagonal to engine compartment) to clear everything.
