engine swap from 2001 Ranger to 2000 Explorer | Ford Explorer - Ford Ranger Forums - Serious Explorations
chum
2000 Ford Explorer 4X4
Hi all, I have a blown engine 4.0 SOHC in a 2000 Explorer 4X4 that I would like to replace with a 4.0 SOHC out of a 2001 Ranger 4X4. Can anyone tell me what all needs to be used from the blown engine in order to make the swap a success? Or is it evan possible to use the 2001 engine? I noticed that the plugs are different and the valve covers. Help will be appreciated.
Chum
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Chum
Just use the long block and whatever else looks the same. The timing cover, oil pan, water pump, balancer ect. are all compatible
chum
engine swap from 2001 ranger to explorer
The engine swap has been completed and worked fairly well, thanks for the information.
The transmission will not shift into overdrive and after a few minutes of driving the od/off light starts to blink. Does anyone have a suggestion as to what might be causing this? The tranny works fine otherwise.
