Engine swap from 2004 explorer to 2005 | Ford Explorer - Ford Ranger Forums - Serious Explorations
william Mccaulley
altoona
2005 Ford Explorer xlt
What is the difference between 4.0L engine out of a 2004 ford explorer and 4.0L engine out of a 2005 ford explorer
william Mccaulley
altoona
where is the IAC located at on my 2005 ford explorer 4.0L
2Trux
Albuquerque, NM
2005 Limited V8 4X4
I believe the 2005 4.0 is drive by wire and does not use an IAC, the electric throttle took over that function.
william Mccaulley
altoona
ok yea it don't have iac and it don't have an MAP Sensor. Got it to idle now but it idles rough.I cleaned the throttle body. i replaced the MAF sensor.I replaced Throttle Position Sensor and the fuel injectors and the Fuel Rail Pressure Sensor
william Mccaulley
altoona
96firephoenix
Indianapolis, IN
2002 Ford Explorer XLT
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
whats on the throttle body
@william Mccaulley
What's on the throttle body is two things: the drive motor, and the Throttle Position Sensor. If either gets messed-up, either on their own or by tampering, the codes for potential engine shut-down will be thrown: "Forced Engine Idle", or "Forced Engine Shutdown".
imp
