nofortunatesonII
- September 14, 2007
I recently purchased an '87 Ford Ranger 2WD with a 2.9 engine that needs a rebuild. The vehicle has no transmission, so I don't have to worry about bellhousing differences. I am interested in replacing the 2.9 with a 3.0 as I have read nothing but negatives regarding the 2.9. The 3.0 sounds to be a much better engine. As far as I know, the firing order is the same (non DIS) between the 2.9 and 3.0. Will I be able to use the 2.9 computer with the 3.0? Will a 2.3 trans out of a '98 Ranger 2WD bolt up to the 3.0L? Any problems I may encounter with this swap??? Thanks.
