engine took a dump | Ford Explorer Forums - Serious Explorations
engine took a dump
FexplorerV8
Houston, TX
97 expedition
I just got me a 94 explorer with a 4.0 motor that took a crap, oil mixed with water and such,
I have a good 4.0 motor out of a 96 explorer, both explorers have an X on the 8th vin digit, I have done a LOT of motor swaps,
I will be using the intake and all electrical out of the 94 the only thing I’m using out of the 96 is the long block, is there anything I should know before I start swapping the motors, I’m concerned with the flywheel bolt pattern specially, any info would be appreciated.
Thanks!
Sure you want to do a motor swap? sounds like you just blew a head gasket.
If it blew a head gasket, it probably has cracked heads. If you've got a 96 motor sitting around that you know is good, use it.
I'm about 95% sure the flywheel bolt pattern is the same. I'm sure someone else will chime in to let you know for sure.
