L_turn9
- June 30, 2018
- Location
- Chester, Va
- Chester
- 2006 Explorer 4.0 V6 4WD
Hi Gang,
This problem has happened 3 or 4 times. 3 out of 4 times were when my wife pulled into our driveway, turned it off and at that moment, the radio and dash lights, warning sounds, etc all stopped. This is not normal. All 4 times have happened when she turned the car off to park. I asked my mechanic and was told it may be the chip in the ignition key going bad. If she tries to re-start it, nothing happens, it's just like when she turned it off to park. There's no dash lights or warning sounds and the engine does not crank at all. Even the doors will not lock/unlock.
Later, it will start and drive like normal. Also, when it gets ready to fail, it starts running roughly. It doesn't turn off but the idle slows down.
The Key has a chip in it and I spoke to a local Lock Shop who said they charge $80 to supply a replacement key. Seems pretty steep to me and I have yet to hear from the dealer.
So far all the times this has happened have been when she was pulling into park here or at a store. Is this something that might happen while driving? I've worked on cars as a hobby for 40+ years and have never seen anything like this. Of course, I usually mess with older cars.
Any ideas?
Thanks,
LarryT
2006 Explorer XLS
Any ideas?
Thanks,
LarryT
2006 Explorer XLS
