Freshmeat
- July 26, 2008
- Denham Springs, LA
- 1994 Ranger STX SC
Okay, so I changed the oil in my Explorer (only 2k on this change, but it's been seven months, so figured I'd knock it out.) It's making plenty of valvetrain noise and also some racket in the bottom end, although it could just be the exhaust throwing me off.
Either way, I'd like to know what would be a decent engine build for this thing so I can start gathering parts when things settle down. Right now I'm rebuilding the 3.0 from my old Ranger so my dad can drive it once in a while (it was my grandfather's truck from new until he passed away in 2005.) Once that's done I'm pulling the motor from my station wagon for a H/C/I swap. Then I'm going to decide whether I chop up and build the HP44 or start building a new motor for the Ex. I have a feeling it'll be motor, unfortunately.
Should I keep the stock bottom end? I've read something about a 95TE head or something along those lines, but every time I try to search it comes up in a cluster of randomness and I'm having trouble getting a decent understanding of its application. Would I use my stock intake on that or would I need whatever intake came with the heads? Can I use the stock pushrods?
I'm not looking for a hot rod motor, but if I could get some extra power while I'm in the process, I'd be willing to piece together different things for a few more ft-lbs.
What are your suggestions on better parts for a simple engine build?
Thanks!
Woodrow
Thanks!
Woodrow
