b33p3rmcg
- September 23, 2007
- N.E. Pa
- 98 XLT
This is another check point for the annoying error code 455. "Gross vapor leak in the Evaporator System". This code usually points to the gas cap as a first check. If the cap isn't the problem, the filler neck, as was the problem for me is a check point.
I have a 98 XLT 4.0 SOHC. Upon original inspection of the neck, it looked old but OK. All other hose inspections looked fine. I decided I would need to drop the fuel tank to find the compromised hose. When I started to disconnect the filler neck hoses to the fuel tank I found the problem. There was a large hole in the filler neck under the hose on the larger tube, but before the hose clamp. I never leaked gas from there when filling the tank but obviously the system couldn't hold vacuum thus the error code.
My quick fix was to sandwich the hole with another clamp placed above it.
I'll replace the neck when I find one.
Hope this helps someone being bothered by that code.
