the manzo
- February 21, 2012
- 1993 ford explorer xlt
hi i have a 93 explorer 4x4 and i have four engine error codes that i dont know how to fix.
the first code is: 335-EGR sensor voltage out of range
the second code is: 124-throttle position sensor voltage higher than expected
the third code is: 327-EGR valve pressure transducer/postion sensor curcuit below minimun voltage
and the fourth code is: 332-EGR valve opening not detected
