Every time you think you will remember, you don't - What is this bolt? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Xylene
1998 XLT V8
1998 Ford 5.0L - I have this bolt sitting around during my engine rebuild, so I know it came off the car. The new bolt came with my head bolts, but I honestly cannot remember where it is supposed to go, nor do I see a place for it to go.
Xylene
1998 XLT V8
looks like an accesory bracket bolt.
That is what I am hoping and as the build goes along its location will become apparent. I have no idea why it came with each set of my new head bolts, its about the same size.
Turdle
The Lowrider is a little higher
Staff member
Moderator
Humboldt, KS
2000 Mounty
there is at least 2 accesory bolts which penetrate into a coolant passage. Corrosion renders them unusable. LIke the water pump timing cover bolts---
Remember this as there will be the same hole on the rear sides of the heads which need to be sealed with threaded plugs.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
That looks to me like a exhaust manifold bolt with a accessory stud. You might not have needed it for your rebuild.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Obviously you don't need it now, so can I have it?
That could be one of the lower timing cover bolts, or one of the corner intake bolts, it's a bit long for a manifold bolt.
fastpakr
Roanoke, VA
99 4wd - 5.0/4R70W/BW4406
Lower timing cover (for the starter wiring harness) is what it -looks- like to me, but why would it be included in a set of head bolts?
Xylene
1998 XLT V8
On the driver sides head there is an accessory bracket. This bolt is one that should be used for the head. It looks like I will be removing one of the bolts from that sides head and replacing it with the one meant for this accessory.
fastpakr
Roanoke, VA
What goes on that bracket? I don't have it installed on mine.
Xylene
1998 XLT V8
If I remember its a single plastic bracket that holds the ignition wire to the spark plug, its a whole lot of metal and brackets for a single wire. Ether that or its a bracket for the O2 sensor wire
Florianópolis, SC
Explorer 2001 Limited V8
Well, the good news: It a external component. Imagine if was internal? But it clear be a component support like other guys wrote. You need to compare with diagrams manual . Maybe it not necessary to change it if you place the component in other support or position...
MakinJeepsWeep!
Polk County Texas
96 Explorer 5.0L AWD
Callsign
Big Red
At first glance i was thinking exhaust manifold bolt with the tab for the dipstick.
Sgfoster57
houston
Explorer sport XLT
It looks like a front cover bolt to me there's several of them actually
leodisalvio
Location
BRAZIL
São Paulo - SP
1993 Explorer XLT V6 2WD
This looks like the starter assembly bolt.
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
Its times like this that make it nice to know people on here really do work on things and are not google warriors. From a picture on a computer we all can narrow down where a bolt goes. Congrats to everyone on here!!!
