EX Radio Wiring... | Ford Explorer - Ford Ranger Forums - Serious Explorations
EX Radio Wiring...
OLDJIMMYBONES
LI, NY
1998 Explorer XLT
I just installed a aftermarket radio, and it works good but when i turn off the car all the presets/settings reset. the radio works on accessory and when started, so i think its hooked up right....
i used this to wire to
Wiring Harness Information:
Constant 12V+ Green/Purple
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
its a kvt719
If you are loosing your settings, it sounds like your switched and constant wires are inverted. I don't understand those colors though- are those the factory colors? Why not use a wiring harness adapter?
i tryed switching the constant & switched and the same problem.
i just wanted it on, didnt feel like getting the adapter so i sniped the wires and attached. yea those are the fact wires
I always use an adapter to install any radio, it eliminates any chance of the problem you are having. They are too cheap to bother with clipping wires.
Recheck your wires....The constant should be light green. BTW its a 98...correct?
Constant 12V+ Light Green
Ground Black
Dimmer n/a
Antenna Trigger Orange/Blue
Antenna Right Front
Right Front (+) Dark Green/Orange
Right Front (-) White/Light Green
Ground Black
Dimmer n/a
Antenna Right Front
yup, 98 xlt. i used the green/purple for the constant. that my problem? dont think i saw an all light green wire back there
Yep....thats the problem. Should be a light green wire in the harness. If you have a dvm check for 12v on the wire.
no idea what a dvm is but there are like 30 extra wires im sure there is a light green in the somwehere, thanks that was becoming a real pain in the ass
DVM = digital volt meter
Yea....any metal on the dash will do. If you have any other questions just ask.....:)
well if you know anything about amps then:
Amplifier Protection Mode
i hooked up my speakers and amp, and they works good when the radio volume is around 10 but any higher it goes into protection mode. i got the ground hooked up to the body. (under the spring loaded carpeted flaps the cover the gap when the back seats are down) i sanded the area, so it was nice shinny metal and bolted it (removed a bolt and replaced it after the wire was in)
if not, thanks anyway, you helped a lot now i can have some presets
How is the Amp hooked up? Are you using RCA's from the new head unit or are you using high level inputs...ie...speaker wires from head unit into amp ?
im using rca's from the head + i got all the lvls on the amp all the way down
would hi imput be any better? wile i pop off the dash for the pwr line i could run a set of high input. (i dont really know **** about amps/subs)
No....low level is actually better as you achieve lower distortion and a better quality signal. A couple of things to look at is ........what size amp, what size power wire, what fuse, how the main power wire is connected to the battery, how the remote trigger wire for the amp is connected....just to name a few.
Normally if the amp goes into protection (if a new amp) leads to a power source problem. If its a used amp it may have weak output transistors....but that goes into a whole other world....LOL
its a 4k amp (but its cheap (lanzar) so im guessing it will put out half that) 4ga power, the amp has 2 35w fuese,the main wire it bolted to the main battery harness, the remote is connected to the head, its new out of the box
is it most likly a bad ground spot? the spot was painted black but i sanded it down to shiny metal. i would take a pic but i left my camera in the other car and that gone til 1
Well it sounds like the amp is well grounded. How are the speakers?
Try this tommorow.....turn the gains on the amp all the way down and try the volume on the head unit. iI its still going into protection I would check the speakers or how they are wired.
BTW.....are they 4ohm subs running one to each channel or bridged? Keep in mind that if you have the subs wired incorrectly that the amp will also go into protection.
i got kicker L7's dual coil at 4ohms, but each are wired parallel so there 2ohms per speaker
yea theres one speaker per channel
ill deff give that a try in the morning
no luck i tryed it a little wile ago and same problem
What level is the Bass Boost at?
