Been noticing this noise for a while but it’s getting worse. I’m assuming it’s coming from the flex pipe?
anyone else have this issue?
Is the flex pipe easy to replace? Will it require cutting? The parts I’m looking at says no but I wanted to ask to see if anyone has replaced this before.
Ended up being the flange right past the flex pipe. Leak due to rust. They welded on a new section instead of replacing the whole thing. Costed only $65 to fix. I lucked out.
I live in Michigan and have had it happen on my 2000 F150 and now the seams on the mufflers of my 2013 Explorer. I might get 2 more years out of the Explorer mufflers but that will be it.
"Stainless steel contains chromium, and when exposed to oxygen it forms a thin invisible layer called chromium oxide. Rust can form when this layer is damaged from exposure to cleaners, chloride, high humidity, high salinity environments, and/or mechanical abrasions.Jul. 9, 2020"
