fixt
- November 15, 2010
- North Carolina
- 1996 5.0L XLT AWD
As part of my quest to improve mileage, I was changing plug wires yesterday and saw that my exhaust manifold on passenger side was cracked, again between #2 and #3 cylinder running down toward the collector. No noise to clue me in, as it was only a a crack instead of fully separated. The previous original manifold had broken completely under the insulation. The replacement was Dorman part 674357 at around 129,800 or so. About 17121 miles on the manifold since 4/25/11 when it was installed.
According to Dorman, Manifold flatness should be within .010 before installation.
They do not come flat, at least mine didn't and was almost .030 from high to low. I'll have the new one milled closer to spec because that job sucks due only to the collector bolts.
From my log book, mileage was at 9-10 prior to replacement with unbalanced readings on O2 sensors, with bank 2 voltage offscale. After replacement mileage improved to 14.2 with O2 bank 2 on scale and changing as it should.
I do not understand bank 2 O2 sensor behaving in such a manner when the problem was the bank 1 (passenger side) manifold. Its possible I wrote it down wrong I suppose.
According to Rock Auto it is warrantied as long as you own the vehicle (limited lifetime). I submitted the claim so we shall see. I do have confidence in Rock Auto. I just received email stating return authorized. Pay first refund later as I expected... but its still covered
Still as good as the original Ford manifold which also broke and was priced at $630 bucks.
Looks like it cracked paralell to their crappy Chinese weld.
This is the original manifold taken off 4/25/11
This was Turdles manifold... same break same place between cylinders #2 and #3
Dorman spec was .010 flatness, here's how it came
