Exhaust manifold... cracked help!
Corik
CA
Explorer '91 XLT 4x4 A4LD
Today I was poking around under the hood and I was putting new clamps on some hoses. I drove the truck for a few minutes to let it warm up and came back. I popped the hood open with the car still on to make sure the clamps sealed well, when I noticed a lot of fumes coming out from the exhaust manifold, I couldn't quite see the crack but I could tell where it must be.
It was on the driver side, and the very back end of the manifold. steam/fumes were coming out and I would like to know what I should do about it?
Should I replace the manifold? I'm light on money right now and probably cant afford new stuff, so is there a easy way to patch this up until I can fix it properly?
Also I don't know if its OK to drive it right now or not.
Delta_1980
livingsville, California
92' exploder
sure you can drive it but the excess heat will eventually damage other things close to the leak. um, i don't know of any products that would seal up the hole under such adverse conditions. probably hard to weld (not impossible)........ just put aside some cash from a couple of pay checks- skip a beer or 2 and buy a new or a good used one.
FIND
Vermillion, SD
99 XLT V8 AWD
If it is cracked, it will have a large effect on fuel economy. If the fumes coming out are exhaust, you should have already been experiencing lower than normal mileage. Outside of that, the likelihood of much damage to anything is low.
Determine whether it is a cracked manifold, a bad manifold gasket or something else. You don't want to spend money where you don't need to. If it is just a bad gasket, then you can do all the repairs for under 15 bucks including buying penetrating lubricant and a wrench if you don't have the right size.
atxexplorer94
austin,tx
94 XLT
When I thought I had a cracked manifold my dad said that you could melt like a copper wire hanger into the crack,Im sure somebody knows more about this method.
1 Is it wrong to install heads with exhaust manifold atached Stock 1991 - 1994 Explorers 5
G Oil leaking from behide the exhaust manifold bad thing? Stock 1991 - 1994 Explorers 1
Number4 Exhaust manifold to pipe bolts Stock 1991 - 1994 Explorers 34
D Thicker exhaust manifold gaskets? Stock 1991 - 1994 Explorers 13
C Exhaust sucking air in...oil leaking by cylinder 6 & manifold Stock 1991 - 1994 Explorers 46
S Flame is coming out of the exhaust manifold. Stock 1991 - 1994 Explorers 18
T manifold exhaust bolts Stock 1991 - 1994 Explorers 5
J driver side exhaust manifold Stock 1991 - 1994 Explorers 0
C Tips on removing exhaust manifold nuts Stock 1991 - 1994 Explorers 6
P Glowing exhaust manifold Stock 1991 - 1994 Explorers 16
B Y pipe with broke exhaust manifold donuts. How to make this work Stock 1991 - 1994 Explorers 0
S 91 Explorer Exhaust manifold removal Stock 1991 - 1994 Explorers 5
M Cat Back Exhaust - Stock or Custom? Stock 1991 - 1994 Explorers 1
D muffler or Cat back exhaust kit Stock 1991 - 1994 Explorers 5
massacre Exhaust Manifolds? Stock 1991 - 1994 Explorers 3
M Exhaust: Muffler Hanger on Wrong End Stock 1991 - 1994 Explorers 0
C 94 Explorer stock exhaust pipe size Stock 1991 - 1994 Explorers 2
C Exhaust system with a silencer of the Russian truck ! Video! Sound! Stock 1991 - 1994 Explorers 6
M Engine Tick or exhaust system? Stock 1991 - 1994 Explorers 8
S Exhaust Replacement on 1991 Explorer Stock 1991 - 1994 Explorers 7
X exhaust flange bolt stuck Stock 1991 - 1994 Explorers 5
P Exhaust pressure / Starting issue? Stock 1991 - 1994 Explorers 3
ld50 Gasoline from exhaust -FPR replacement Stock 1991 - 1994 Explorers 11
S Exhaust question Stock 1991 - 1994 Explorers 5
EMBRACETHEHATE89 exhaust leak Stock 1991 - 1994 Explorers 5
W Exhaust Leak Stock 1991 - 1994 Explorers 3
Number4 Getting to exhaust manif. nuts Stock 1991 - 1994 Explorers 12
K Terrible exhaust noise Stock 1991 - 1994 Explorers 2
L.A.X Ripped out my stock 1st Gen exhaust Stock 1991 - 1994 Explorers 5
R need urgent help with my exhaust Stock 1991 - 1994 Explorers 1
mr cribb new top end, now oil is blowing through the exhaust Stock 1991 - 1994 Explorers 25
mr cribb Horrendous exhaust odor Stock 1991 - 1994 Explorers 21
W Heads and Exhaust Bolts Stock 1991 - 1994 Explorers 13
W Dual Exhaust Stock 1991 - 1994 Explorers 15
A Exhaust Help!!! Stock 1991 - 1994 Explorers 4
D DynoMax Exhaust Stock 1991 - 1994 Explorers 17
T 94 Eddie; Carbon from exhaust; carbon fouled plugs... Stock 1991 - 1994 Explorers 29
S Exhaust Removal Stock 1991 - 1994 Explorers 4
D exhaust question on Navajo Stock 1991 - 1994 Explorers 5
1 Exhaust preference/opinions wanted. Stock 1991 - 1994 Explorers 8
W Exhaust flange gasket and spring/bolts? Stock 1991 - 1994 Explorers 3
B Exhaust redo for '94 Eddie Bauer @ 190k Stock 1991 - 1994 Explorers 4
P $60 cat back exhaust Stock 1991 - 1994 Explorers 10
D Gurgle/popping exhaust plus IAC troubles Stock 1991 - 1994 Explorers 0
C Quiet exhaust advice. Stock 1991 - 1994 Explorers 3
B No Resonator on Exhaust Stock 1991 - 1994 Explorers 6
S New Exhaust Pipes. Stock 1991 - 1994 Explorers 12
J exhaust leak! Stock 1991 - 1994 Explorers 1
M White smoke and gasoline coming out of exhaust? Stock 1991 - 1994 Explorers 5
F Exhaust questions. Stock 1991 - 1994 Explorers 3
Similar threads
