rathrbcruisin
- September 17, 2015
- Michigan
- 1998 Explorer 5.0 AWD
The truck has been running pretty good, so of course on my way into work I pass this car and the exhaust got loud and sounds like and old tractor chugging along. I've already had the egr tube replaced. and thats what it sounds like again. so i'm thinking it may be that small nut going into the manifold. or it could be a crack in the manifold. it is quiet at idle, and if you dont push it too hard it's not bad. I'm sure its going to get worse so i'm getting my info to change the manifold. I would rather do it in the summer, than the freezing cold of winter.
I've seen there are a couple different types. dorman and atp seem to be available. dorman is cast iron, atp you can get cast iron, or steel. is the cast iron usually what everyone gets?
I havent seen many horror stories about breaking off studs. If you did break off a stud can you drill it out and use a heli coil? not sure what else you could do.
Any advice? 98 explorer 5.0, working on passenger side.
