Exhaust recall question | Ford Explorer - Ford Ranger Forums - Serious Explorations
asull85
The Storm Chaser
Agawam, MA
2016 Interceptor Utility
Callsign
WX4FUN
Have any of you had your PIU at the dealer for the exhaust recall? Other than modifying the tailpipes, what else did they do? I scheduled mine to go in on January 2. I was also informed they wouldn't be giving me a loaner while the work is done. Nice right?
2013PIU
WALNUT CREEK, CA
2013 PIU
On top of welding turn downs to the exhaust tips the dealership added a heavy duty lift gate weather strip and double checked that all holes for auxillary lights were plugged. They also reprogrammed the AC to circulate fresh air under hard acceleration. If it hasn't been done recently it may also be a good time to have the transmission fluid flushed as mine was nasty.
KayGee
Farmington, MI
'16 & '17 PIU
That TSB is a lot of work and there are a lot of opportunities for inexperienced/rushed techs to do some damage to a vehicle.
I'm going to take a hard pass on having the exhaust tips ground off and downturns welded on. That is a totally half ass repair job.
I'll take the upgraded liftgate weatherstrip, but I didn't see anything mentioned in the TSB about it. Do you have a part number?
I think I had the updated HVAC programming done as there was a line item on my last RO, but I'll have to confirm if it was the update applicable to the TSB or something different.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Is it just me or does anyone else think after reading all those instructions they are not sure where the root of the problem is. That's a ton of warranty work payout.
