Explorer Long Travel Kits | Page 2 | Ford Explorer Forums - Serious Explorations
What will be tire size with the kit ? Also will the torsion bars be retained or ditch in favor of a coil over system? Very interested in the kit for my 97sport let me know if you need someone for R&D.
I looked at your site and answered some of my own questions. I did want to say I saw you guess on OFF ROAD A-Z congrats also do you know how your suspension system will fit score's regulations on certan classes ?
Thanks, that was pretty cool to be featured on TV... They did a really good job of showing what Off-Road racing is all about.
The only classes that this suspension would fit into would be 'Sportsman' Truck or maybe Class 7 Open... I would have to check the width. And with that being said, Class 7 Open is a open class with open rules Re: suspension pivots and geometry. Really crazy ($$$) stuff.
Aaron
DBR-Edge if you could figure that out and get in touch with me cause I would like to figure out how to set my truck up to come racing next season. Right now it is a stock 97 explorer sport but I am building an egine and transmission and would like to hold off to know the rules and class etc so I know what I can and cannot do. Email me if you get a chance. Adam
This may sound stupid, but what does shocks have to do with the lift? Does it add anymore lift to a tt and rear shackles? I've notice I have a bad shock on one driver side of the rear that causes a pretty noticeable lean.
WOW....this thread is almost 10 years old....!!! lmaooo
anyway....your drivers side rear shock IS NOT causing the lean.
shock will absolutely NOT give you any lift, the dixbros shock
is a coilover, which is the same as the 3rd gen Xs.
with the dixbros suspension, you would be 86ing the torsion set-up.
a flattend out leaf spring is whats causing your driver side gangsta lean.
:salute:
Back from the dead. Unless you have a large body nitrogen filled shock its not the shock that is causing the lean, as stated above. You could have an extremely worn or torsion as well.
With the coilover shock you must run on this kit you can adjust your ride height to that of you specific liking with the pre load collar
anyone have this kit? Really thinking about getting it in the future.
Sorry to open up such an old thrad but I wanted to let everyone know we have taken over for Dixon Bros Racing and will be producing all their kits. Let me know if you have any questions.
What will you be doing for CV axles?
^^what he said
THERE WILL FINALLY BE A Long-Travel Kit out for EXPLORERS!!!
We are just finishing up a brand new suspension kit for the Rangers and Explorers. This kit will work for 2wd, and 4wd. Here are some features:
Approx 4" wider per side
New Upper and Lower A-Arms
15" of Travel
2.5" Coilover Shocks
Hyd Bumpstop
New longer 4wd half-shafts
Check here for more information:
http://www.dixonbrosracing.com/products.htm
Aaron
do you offer a long travel kit for 89-97 ranger or 90-94 explorers?
