Explorer mods have started | Ford Explorer - Ford Ranger Forums - Serious Explorations
2damslo
Southern Maryland
2014 Explorer Base
Finally started on the explorer mods With Auto vent visors, Led headlight setup, added led fog lights, Blacked out the grill, added the explorer letters along with H&R springs and Niche 22in wheels
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
How are you attempting to load your pictures? The easiest way is to take out a $20 Elite membership and you can use the "Upload a File" options available with eavh post. You will be able to post directly from your device. This will also save them to our servers. The other option is to use a 3rd party posting site like Photobucket but those pictures have a habit of disappearing after a period of time.
Also, please complete your profile by adding the trim level of the Explorer to it. It will then show in the margin every time you post. That can at times be very helpful info.
jonnoriega
Location
Northern IL
Streamwood, IL
2016 Ford Exp Platinum
Yes. It's about a nickel a day. I think I spent more on breakfast today than what it costs to be a Elite Explorer in this forums :p
tsawyer
Westchester, NY
2014 Explorer Sport
Looking good. How did you find the process of removing the front grill? I've only found one post that covered removing just the center grill piece without doing the whole front fascia/bumper. That described removing the screws across the top, and then reaching in to get to four somewhat trickier nuts from behind the grill. Was that your experience or did you find a better / easier way?
2damslo
Southern Maryland
2014 Explorer Base
I pulled the front bumper cover off its not bad took about 15 mins or so to pull the bumper cover hardest part was taking the grill off without breaking any of the tabs. There is screws across the top, bottom, and
one in each fender well under the wheel well trim
peterk9
Staff member
Moderator
Callsign
VE3
Thank you for taking out a membership that also helps to support the Forum. Once a year during the Black Friday/Cyber Monday time frame Rick will offer a 2 for 1 membership deal so you can get 2 years for that price.:D
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum and thank you as well for becoming an Elite member.:wave:
ECF
San Jose, CA
2017 Ford Explorer Sport
Which Niche wheels are those? The Misano? And what tire size did you go with?
2damslo
Southern Maryland
2014 Explorer Base
Targa and 265/40/22 as the height are within .001in of the factory tire
2damslo
Southern Maryland
2014 Explorer Base
Thank you and yes in Anthracite with a polished stainless steel lip
Fentress24
Maryland
2016 Ford Explorer Sport
Looks good!
Have you had polished lips on a vehicle before? I had them on my Infiniti which I drove everyday and I promised myself I will never do it again. Anytime they get wet I would have to wipe them down or they would look like crap. If it was raining and the rain pooled up on the lip it would leave water marks which had to be polished out. After a couple years they started to pit and I had to spend hours sanding and re-polishing them.
I would recommend getting a clear coat put on the lip to protect them, or avoid bad weather with them!
Just some friendly advice!
ECF
San Jose, CA
Sorry, forgot to ask if those are 22x9s? Do you know the offsets? I like how the tires fit; not too thin.
2damslo
Southern Maryland
2014 Explorer Base
Yes 22x9 and not sure of the offset and i don't see it in the paper work anywhere if i find out i will let you know
ECF
San Jose, CA
